xconnect on SVI interface ES Cards on 7606
Aug 19th, 2009
Is it possible to configure xconnect from an SVI interface, when your core facing cards are RSP-720?
I have configured it:
interface Vlan290
no ip address
xconnect 10.10.136.129 37123712 encapsulation mpls
end
It does not come up:
PE4#sh mpl l2transport vc
Local intf Local circuit Dest address VC ID Status
Vl290 Eth VLAN 290 10.10.136.129 37123712 DOWN
PE4#sh mpl l2transport vc 37123712 det
PE4#sh mpl l2transport vc 37123712 detail
Local interface: Vl290 up, line protocol up, Eth VLAN 290 up
Interworking type is Ethernet
Destination address: 10.10.136.129, VC ID: 37123712, VC status: down
Output interface: none, imposed label stack {}
Preferred path: not configured
Default path: no route
No adjacency
Create time: 00:00:49, last status change time: 00:00:03
Signaling protocol: LDP, peer 10.10.136.129:0 up
Targeted Hello: 10.10.136.131(LDP Id) -> 10.10.136.129
Status TLV support (local/remote) : enabled/not supported
Label/status state machine : remote ready, LndRru
Last local dataplane status rcvd: no fault
Last local SSS circuit status rcvd: AC DOWN(rx,tx faults)
Last local SSS circuit status sent: no fault
Last local LDP TLV status sent: no fault (withdrawn)
Last remote LDP TLV status rcvd: not sent
MPLS VC labels: local unassigned, remote 340
Group ID: local unknown, remote 0
MTU: local unknown, remote 1500
Remote interface description: ** Test PW with PE4 ES SVI int **
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, seq error 0, send 0
Although when I use a physical interface it comes up?
RSp720 does not support it??
Atif Siddiqui Thu, 08/20/2009 - 11:14
I moved my core facing link to ES card instead of RSP 720 and it works.
PE4#sh mpls l2transport vc
Vl290 Eth VLAN 290 10.10.136.129 37123712 UP
but now i am thinking what we can use the RSP-720 gige ports for.
Giuseppe Larosa Fri, 08/21/2009 - 02:31
  • Hall of Fame,
    Founding Member
Hello Atif,
I had that same doubt that ES card has to have the core facing interface.
management :)
Hope to help
Giuseppe
Atif Siddiqui Fri, 08/21/2009 - 05:30
Also in QoS RSP720 does not support prirotity queueing for real time traffic... not sure why we don't have all this in this latest SUP for 7600.
