How to delete backup.lock
Answered Question
Aug 19th, 2009
Hi Experts,
I have stop the daemon manager but I am still unable to delete the backup.lock.
Pls advise.
Thanks and Regards,
YS
Correct Answer by Joe Clarke about 7 years 6 months ago
The DEL /F command reports the same thing? If so, a backup process may still be running (backups are run out of Windows AT, not Daemon Manager). Check for any running Perl processes, and kill them. Then try and remove the lock file. If in doubt, reboot.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 08/19/2009 - 19:43
What error do you get trying to delete it? What if you use DEL /F from a DOS prompt?
jeeyishyuan Wed, 08/19/2009 - 20:45
Hi Joe,
The error shown Can't delete the file as it is used by another person or another process.
Correct Answer
Joe Clarke Wed, 08/19/2009 - 20:53
