Smallest switch that support VRF ?
Aug 19th, 2009
Hi all,
in my labs, i am looking for the smallest SWITCH + IOS that supports VRF ?
Can you please tell me which model ?
Thank you
yann.boulet Wed, 08/19/2009 - 21:59
Hi thank you for the quick reply, I don't really know what's the difference.
I want to create routing contexts on the same physical equipment.
Thank you
Giuseppe Larosa Wed, 08/19/2009 - 21:58
Hello Yann,
the 3560 model should support 8 VRFs
the 3560-8PC with 8 ports is the smallest one but a 24 ports model can be a better choice.
You need also the ip services image
>>To use multi-VRF CE, you must have the IP services image installed on your switch.
as Leo noted this is for VRF lite no mpls support.
Hope to help
