Incoming call loadbalancing with CUCM
Aug 19th, 2009
Can anyone please help me to configure load balacing with CUCM in gateway.
For example: Suppose I have dial-pattern x.x.x.x and three CallManager Pub,sub1 & sub2 in this case I have to configure preference in each dial-peer to select the
CallManager for incoming calls from PSTN on gateway.
In above configuration next CallManger is used only when first CallManager is not available.
Is there any way to configure so that first incoming call will go to first CUCM,2nd call will go to 2nd CUCM and so on.
MARTIN STREULE Mon, 08/24/2009 - 03:17
  • Silver, 250 points or more
"dial-peer hunt" may help you.
Router(config)#dial-peer hunt ?
<0-7> Dial-peer hunting choices, listed in hunting order within each choice:
0 - Longest match in phone number, explicit preference, random selection.
1 - Longest match in phone number, explicit preference, least recent use.
2 - Explicit preference, longest match in phone number, random selection.
3 - Explicit preference, longest match in phone number, least recent use.
4 - Least recent use, longest match in phone number, explicit preference.
5 - Least recent use, explicit preference, longest match in phone number.
6 - Random selection.
7 - Least recent use.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_confg.html
