CUBE with transoding, dtmf issue
Aug 19th, 2009
Hi, gurus!
Need your help again..
Cisco 2811 recieves call from VOIP provider via h323, g729r8, fast start, dtmf-relay type is h245-alphanumeric.
Outgoing call must have the same parameters.
This Cisco executes an TCL/VXML IVR, after which the incoming call is connected to operator, which, in some cases, is a cellular phone, so that setup is made again from this Provider (looks like ipsec-on-stick).
When call setup is done, operator has oportunity to transfer call to a more qualified specialist pressing "0". But cisco does not recieve dtmf.
Here is my config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
h323
no call service stop
call preserve
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 6
associate application SCCP
! incoming peer, translate 84959888053->9888053
dial-peer voice 1 voip
translation-profile incoming 1
destination-pattern 84959888053
session target ipv4:this Cisco IP
incoming called-number 84959888053
dtmf-relay h245-alphanumeric
no vad
! transcode and send to IVR script on g711
dial-peer voice 2 voip
service ivr
destination-pattern 9888053
incoming called-number 9888053
codec g711ulaw
no vad
! when operator is selected, we need to play him a info message (so once again we use translation and transcoder)
dial-peer voice 916739 voip
description -=Operator1=-
translation-profile incoming 9
destination-pattern 989167396844
session target ipv4:this cisco IP
incoming called-number 989161182155
codec g711ulaw (we need to play msg!)
no vad
! after transoder and "9"-stripping send to operator(g729,alpha)
dial-peer voice 100 voip
destination-pattern 8..........
session target ipv4:X.X.X.X
no vad
And operator cannot send DTMF.
UPD: i think that the problem is in call legs created in this call. SCCP call legs use strictly inband Dtmf type, and H323 use h245-alphanumeric dtmf-relay.
