I need to connect a few systems at 10Gbps to a CISCO 4900M.
The base 4900M unit has 8 X2 connections built-in.
Am I right in saying if I use a 10Gbps-CX4 network card, I need to purchase a X2-10GB-CX4 tranceiver module for each network card?
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/installation/note/78_16705.html
Is there an alternative / recommended 10Gbps network card that can be used to connect directly to the onboard X2 connections without a tranceiver module?
Mario
