CME Partition and CSS ?
dsuntama
Anyone can help me how to use the Partition and CSS on CME as on CUCM ?
For example my client have 3 x ISDN 2
they need to dial prefix 9 to call out
and what they need is
ext. 1 call out using bri 0/0/0
ext. 2 call out using bri 0/0/1
ext. 3 call out using bri 0/1/0
How to configure the calls will go to different BRI as all using the same dial peer with destination pattern 9T ?
Thanks in advance
David
10 Replies 10
Partitions and CSS dosen't exist on CME. Check cor lists to do similar thing.
COR vs Cisco CallManager
The COR feature in the Cisco IOS Software feature is like a Cisco CallManager calling search space and partitions.
Cisco IOS Software bases its restriction via dial-peer matching. The Cisco CallManager does it based on digit analysis.
The dial-peer cor custom command is equivalent to creating Cisco CallManager partitions.
The dial-peer cor list command is equivalent to creating a Cisco CallManager calling search space with partitions in it.
More info here: http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Thanks for the reply
But for my case, how the COR will be implemented ?
Any idea ?
Did you manage to sort out the issue? I have got the same request from a customer. Please let me know. I am also working on the cor configuration.
Chandrasen
I still can't find out the using of COR for this scenario.
Temporary Im using different prefix (dial peer pattern) to call out to different BRI port
Anyone can help ?
Rgrds,
David
This can be implemented with a combination of dial peers and voice translation rules. See the following link.
http://supportwiki.cisco.com/ViewWiki/index.php/Mapping_Outbound_VoIP_Calls_to_Specific_Digital_Voice_Ports
Hope this helps.
Brandon
Thanks for the reply. We have now implemented the above using COR lists as per the following configurations. We have 2 companies, TMS and BRAM and we worked out the configuration such that the TMS users press 9 to pick up a line, they always select a specific line while when the BRAM users press 9, they always select another line.
Here is the configuration:
name nat-TMS
name internat-TMS
name nat-BRAM
name internat-BRAM
dial-peer cor list nat-TMS
member nat-TMS
dial-peer cor list internat-TMS
member internat-TMS
dial-peer cor list TMS1
member nat-TMS
member internat-TMS
dial-peer cor list TMS2
member nat-TMS
dial-peer cor list nat-BRAM
member nat-BRAM
dial-peer cor list internat-BRAM
member internat-BRAM
dial-peer cor list BRAM1
member nat-BRAM
dial-peer cor list BRAM2
member nat-BRAM
dial-peer voice 1 pots
corlist outgoing nat-BRAM
description [ national direct dial - longest match ]
huntstop
preference 1
destination-pattern 9[2-9]......
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
port 0/0/1:15
forward-digits 7
dial-peer voice 2 pots
description [ local direct dial - variable length ]
huntstop
preference 2
destination-pattern 9[8]T
direct-inward-dial
port 0/0/1:15
forward-digits 4
dial-peer voice 3 pots
huntstop
preference 3
destination-pattern 91[1,5,7].
direct-inward-dial
port 0/0/1:15
forward-digits 3
dial-peer voice 4 pots
huntstop
preference 4
destination-pattern 910...
direct-inward-dial
port 0/0/1:15
forward-digits 5
dial-peer voice 5 pots
corlist outgoing internat-BRAM
description [ international ]
huntstop
destination-pattern 90T
direct-inward-dial
port 0/0/1:15
prefix 0
dial-peer voice 10 pots
corlist outgoing nat-TMS
huntstop
preference 1
direct-inward-dial
port 0/0/0:15
forward-digits 7
dial-peer voice 11 pots
huntstop
preference 2
direct-inward-dial
port 0/0/0:15
forward-digits 4
dial-peer voice 12 pots
huntstop
preference 3
direct-inward-dial
port 0/0/0:15
forward-digits 3
dial-peer voice 13 pots
huntstop
preference 4
direct-inward-dial
port 0/0/0:15
forward-digits 5
dial-peer voice 14 pots
corlist outgoing internat-TMS
huntstop
direct-inward-dial
port 0/0/0:15
prefix 0
Chandrasen
Hi Chandrasen,
Thanks for sharing.
I would like to know how you configure the COR on the ephone-dn ??
For example:
ephone-dn 1 dual-line
number 4102
label 4102
call-forward busy 5000
call-forward noan 5000 timeout 20
corlist incoming BRAM1
if you want ephone-dn 1 to access national and international dial-peer and
number 4102
label 4102
corlist incoming BRAM2
if you want to access only NAtional dial-peers.
Hope this helps.
Chandrasen
Hi Chandrasen,
Thanks for your advise..
Will let you know the result once I apply this to my client
Rgrds,
David
No, it does not but uses a dial peer instead. Your problem could be corrupt dial peer.
