"ip tcp adjust-mss" on interface Port-Channel
Aug 20th, 2009
Hi Sir,
I have the following port channel config on a Cisco 7609:
interface Port-channel1
ip address 10.10.10.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf message-digest-key 1 md5 cisco123
logging event link-status
no mpls ldp igp sync
service-policy input POLICER
service-policy output POLICER
interface GigabitEthernet2/1
no ip address
no cdp enable
channel-protocol pagp
channel-group 1 mode desirable
interface GigabitEthernet2/6
no ip address
no cdp enable
Module 2 is a WS-X6724-SFP.
I want to configure the "ip tcp adjust-mss" command on the interface. Please advise whether I should apply the command on the Port-Channel or the physical interfaces or both.
Thank you.
B.Rgds,
Lim TS
Giuseppe Larosa Thu, 08/20/2009 - 02:01
Hello Lim,
you can configure a command regarding TCP OSI layer4 only on L3 interfaces so member links of the port channel don't need it.
You may need to consider a change on interface mtu and ip mtu.
Also I would consider if the command has to be given on the layer3 interface on the client Vlan.
It is likely that th bundle is a core facing link.
So it may be the wrong place for the command also on the logical interface
Hope to help
Giuseppe
limtohsoon Thu, 08/20/2009 - 02:27
Hi Giuseppe,
Thanks for your reply.
The port-channel interface is facing client.
Thank you.
B.Rgds,
Lim TS
Peter Paluch Thu, 08/20/2009 - 03:01
Hello Lim,
Please allow me a question: Why do you want to use the "ip tcp adjust-mss" command? Do you have a special reason to manipulate the MSS?
Best regards,
Peter
