No ip for matching mac on Cisco Switch 6509
Aug 20th, 2009
Weird issue has cropped up. I have a total of 4 X Cisco 6509 switches in 2 data-centres. Multiple VLAN's exist on each switch...
However, I have a problem on 6 individual ports.....Really weird issue in that every 30 minutes without fail the ports reset themselves...
For 4 out of the suspect 6 ports, a Mac-address has been discovered on all of the ports but no corresponding IP....All of the mac addresses indicate that they are the same vendor...all begin with 001b.4f0c....
On the suspect ports as well, there is little or no traffic coming in from the affected device and what is is primarily broadcast traffic....
see interface output below
any ideas?
Mary
test_switch#sh int gig 1/12
GigabitEthernet1/12 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 001b.534a.3fab (bia 001b.534a.3fab)
Description: **Sys1-CTLA_Ipsi 6a-10.239.48.18**
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output never, output hang never
Last clearing of "show interface" counters 19:24:44
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1000 bits/sec, 2 packets/sec
1377 packets input, 88184 bytes, 0 no buffer
Received 1370 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
180378 packets output, 11831356 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
test_switch#
test_switch>sh mac-address-table int gig 1/12
Legend: * - primary entry
age - seconds since last seen
n/a - not available
vlan mac address type learn age ports
* 601 001b.4f0c.ede6 dynamic Yes 40 Gi1/12
test_switch>sh arp | include 001b.4f0c.ede6
test_switch>
test_switch#sh run int gig 1/12
Building configuration...
Current configuration : 306 bytes
interface GigabitEthernet1/12
description **Sys1-CTLA_Ipsi 6a-10.239.48.18**
switchport
switchport access vlan 601
switchport mode access
no ip address
logging event link-status
speed 100
duplex full
mls qos trust dscp
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
end
test_switch
Aug 20 10:09:48.303 GTM: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/12, changed state to down
Aug 20 10:09:48.351 GTM: %LINK-3-UPDOWN: Interface GigabitEthernet1/12, changed state to down
Aug 20 10:09:48.302 GTM: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/12, changed state to down
Aug 20 10:09:48.350 GTM: %LINK-SP-3-UPDOWN: Interface GigabitEthernet1/12, changed state to down
Aug 20 10:09:50.431 GTM: %LINK-3-UPDOWN: Interface GigabitEthernet1/12, changed state to up
Aug 20 10:09:50.431 GTM: %LINK-SP-3-UPDOWN: Interface GigabitEthernet1/12, changed state to up
Aug 20 10:09:50.435 GTM: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/12, changed state to up
Aug 20 10:09:50.435 GTM: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/12, changed state to up
ktwaddell Thu, 08/20/2009 - 06:39
have the cables been trace back to these 6 ports? To find out what is connected to them.
Cheers
Kev
maryodriscoll Thu, 08/20/2009 - 06:56
No, not yet, they are being traced tomorrow...As soon as I know I'll update this converation but I think that they are network cards from an Avaya PBX....
Jon Marshall Thu, 08/20/2009 - 09:41
Mary
001b.4f0c is definitely Avaya.
Is vlan 601 dedicated for Avaya PBX stuff or do you have other devices in that vlan as well.
Is there a chance you could repatch at least one of the ports and into a different module and then see if it still goes down with the others.
It may well be something the Avaya PBX is doing rather than the switch itself. Repatching would help to narrow this down.
Jon
maryodriscoll Fri, 08/21/2009 - 05:50
Jon
Vlan 601 is dedicated for the Avaya Kit alright but most are okay. I've an engineer going to site today to trace them for me as they could be going into different cards in the pbx e.g. clan card, medpro etc.,
mary
