IPSec VPN Connectivity Issue
Answered Question
Aug 20th, 2009
Ok i have the following configuration. One asa 5540 is the vpn server and through site to site vpn's some cisco 2811 routers connect to it. All cisco routers have the same ip in their internal interface so i am nat'ing them to another ip to connect to the vpn. The same goes for the servers behind. So we have
ip nat inside source static 10.0.10.10 10.1.89.10
ip nat inside source static 10.0.10.30 10.1.89.30
Where .10 is the server and .30 is the router. The vpn comes up and i can pint from the server to my internal network lets say to server 10.0.20.10. From server 10.0.20.10 i can ping both the nat'ed ip's. However i cannot ping 10.0.20.10 from the routers. Also i try pinging 10.1.89.10 on the router and it pings fine. On the other hand pinging 10.1.89.30 does not when 10.0.10.30 does. PLEASE HELP. I need the router to be able to communicate with 10.0.20.10 sever.
Thanks in advance.
Overall Rating: 5 (1 ratings)
tkatsiaounis Thu, 08/20/2009 - 02:52
My goal is to have full connectivity and not just ping. I will try though. As far as the design is concerned thank god it was not mine. And indeed it sucks.
tkatsiaounis Thu, 08/20/2009 - 03:19
I have tried extended ping and when i specify source ip address 10.0.10.30 it does ping normally. What can i do to establish full connectivity????
