ACNS on WAAS VB
Paul Pinto
Goodday,
I was wondering if there are any current deployments of ACNS on WAAS VB?
If so, are there any recommended implentation guides (SRDN's, CVD's, etc.)
Any limitations (like version ACNS, WAAS, memory allocation, Disk space allocation, etc.)
Any suggestions or guidence would be greatly appreciated.
Thanks.
drolemc
Level 6
Level 6
The ACNS-VB software allows ACNS 5.5.13 to run on a WAAS virtual blade and be managed from the Central Distribution Manager. You can install the ACNS-VB software on an existing WAAS device, or migrate your ACNS device to WAAS first, and then install the ACNS-VB software. In the Disk Space field, allocate the amount of WAE hard disk space by specifying up to four disk values (separated by a space), in gigabytes, that you want allocated for the virtual blade.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v413/aow/guide/acnsvbguide.html#wp61648
