Rob Huffman Thu, 08/20/2009 - 04:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi PPD,
I believe the sequence is;
Settings> Phone settings> Press **2, it will display "start factory reset now"> Select Yes
Hope this helps!
Rob
Rob Huffman Thu, 08/20/2009 - 05:22
  • Hall of Fame,
    Founding Member
Hi PPD,
You are most welcome my friend!
Cheers!
Rob
bobliu001 Tue, 10/04/2016 - 20:03
thanks !
this  is also  useful  for me  to  reset  wifi phone 7925
