LMS Running Status
Aug 20th, 2009
Hello, This morning our LMS application is down, when trying to get to the login screen we are returned Page can not be displayed. What are the areas that need to be checked first to resolve this, processes, web server. Are there any commands that return the status or health of LMS. We are running our instance of LMS on Solaris. Thanks for the help
Joe Clarke Thu, 08/20/2009 - 06:34
It sounds like either Apache or all of LMS has been shutdown. First, check the output of the /opt/CSCOpx/bin/pdshow command. Make sure Apache is still running. If that command fails, then Daemon Manager has most likely been shutdown. You will then need to run:
/etc/init.d/dmgtd start
downeast75 Thu, 08/20/2009 - 09:20
Thanks for the help jclarke, I ended up restarting the daemon manager to correct the issue. FYI, the pdshow did fail. For future reference if it ever turns out that Apache had failed, what are the commands to restart Apache? Again, I appreciate all the help
Joe Clarke Thu, 08/20/2009 - 09:22
If Apache alone has just failed, you can restart it with the pdexec command:
/opt/CSCOpx/bin/pdexec Apache
However, more than likely, other processes will have died as well. In that case, restarting dmgtd is the best option:
/etc/init.d/dmgtd stop
