CSS/ACE response time for HTTP 200 ok
Aug 20th, 2009
Is there any show command available for CSS/ACE to display eg. HTTP 200 response time per client request.
Our SLA is to serve HTTP200 within 1 sec after the 1st request is send to web server from the CSS/ACE
My search on this forum suggest sniffer. Any other alternative.
Kelvin
Gilles Dufour Thu, 08/20/2009 - 06:18
Are you trying to make sure the ACE/CSS does not delay the response ?
Or do you want the ACE/CSS to detect if the server is too slow to respond ?
On the ACE you can set a probe max response time to 1sec and if the response does not come within this time, the probe goes down.
The command on ACE, under the probe config is :
receive Configure max time to wait inorder to receive reply from server
Otherwise, the sniffer trace if you just want to have a look and make sure about the time.
Gilles.
