AAA Different Permissions again
Answered Question
Aug 20th, 2009
In a previous post I asked how I could assign RO permissions when a user connects to a firewall, but RW access when they connect to a switch, I was given a Cisco Kb to follow but this only allows the user to be in a RO or RW group.. I need the same user "Joe Blogs" RO access for one device and RW for another.
Correct Answer by Jatin Katyal about 7 years 10 months ago
Under the user account >> Look for this radio option
Assign a Shell Command Authorization Set on a per Network Device Group Basis.
Attached is the screen shot of the same.
Overall Rating: 5 (2 ratings)
Jatin Katyal Thu, 08/20/2009 - 07:23
  • Cisco Employee,
This is what I explained you in my last update to your POST.
Please check again.
Plz let me know if you face any issue.
JK
networker99 Thu, 08/20/2009 - 08:03
I followed your post but how does it know when to use the RW group as opposed to the RO group?.. I can only place the user in one group..
Jatin Katyal Thu, 08/20/2009 - 08:56
  • Cisco Employee,
This can be done by creating two NDG's and map them with respective command authorization set under the same user account.
Creating NDG's
NDG1 for ASA ---add ASA as a aaa client
NDG2 for switch---add switch as aaa client.
Creating command authorization set
Create two different command authorization set under shared profile component for
Switch = permit all
ASA = Deny all
and permit show only
Now, under the user account you need to map the NDG with appropriate command authorization set. When user tries to login to switch/ASA it will check the authorization set mapped with their NDG's
JK
networker99 Thu, 08/20/2009 - 09:09
"Now, under the user account you need to map the NDG with appropriate command authorization set." I cant see how to do this.
Correct Answer
Jatin Katyal Thu, 08/20/2009 - 09:41
  • Cisco Employee,
Jatin Katyal Thu, 08/20/2009 - 10:17
  • Cisco Employee,
This does exist in 4.1.x
You need to enable this feature on the ACS under interface configuration > Advanced Options > check this option "Per-user TACACS+/RADIUS Attributes"
After that click on cancel > go to TACACS+ (Cisco) > check this option "Shell (exec)" for user > hit submit and you are done :)
networker99 Thu, 08/20/2009 - 10:29
Thanks, but I only have
-None
-As Group
-Assign a Shell Command Auth for any network device
-Per User command authorization
I dont have "Based on per network device group basis"
networker99 Thu, 08/20/2009 - 10:41
Got it !! didnt have NDG selected under interface options
