7609 - CEF with multiple VRFs
Aug 20th, 2009
I have a 7609 with multiple VRFs (VRF Lite).
Below is a sh mod
Mod Sub-Module Model Serial Hw Status
1 7600 ES+ DFC LITE 7600-ES+3C 1.0 Ok
1 7600 ES+ 20xGE SFP 7600-ES+20G 1.0 Ok
5 Policy Feature Card 3 7600-PFC3C 1.1 Ok
5 C7600 MSFC4 Daughterboard 7600-MSFC4 1.1 Ok
6 Policy Feature Card 3 7600-PFC3C 1.1 Ok
6 C7600 MSFC4 Daughterboard 7600-MSFC4 1.1 Ok
8 Centralized Forwarding Card WS-F6700-CFC 2.0 Ok
9 ESM20G/PFC3C Distributed Fo 7600-ES20-D3C 1.0 Ok
9/0 10XGE Port 7600-ES20-20GE 1.0 Ok
9/1 10XGE Port 7600-ES20-20GE 1.0 Ok
When I issue the command show cef linecard detail I get the following output.
CEF linecard slot number 5/0 (5), status up
Input packets 7451981697, bytes 9737285426086
Output packets 0, bytes 0, drops 0
CEF Table statistics:
Table name Status
IPv4:x-voice Inactive
IPv4:public Inactive
IPv4:x-video Inactive
IPv4:x-server Inactive
IPv4:x-lan Active, sync, table-up
IPv4:x-mgmt Active, sync, table-up
IPv4:net Active, sync, table-up
IPv4:Default Active, sync, table-up
IPv6:Default Active, sync, table-up
CEF linecard slot number 9/0 (9), status up
Input packets 4546951053, bytes 3153775353471
Table name Status
CEF linecard slot number 6/1 (20), status up
Input packets 0, bytes 0
Table name Status
IPv4:x-voice Active, sync, table-up
CEF linecard slot number 6/0 (6), status up
Table name Status
Can anyone tell me why I am getting a status of inactive in some VRFs and active in others.
The configuration of all VRFs and associated l2 and l3 interfaces are similar and I cannot see what might be causing this.
A
Laurent Aubert Fri, 08/21/2009 - 09:04
It's a cosmetic issue so don't worry about it. This command is not relevant for 7600 chassis
Laurent.
