Upgrade of 1131AG to LWAPP fails. "Invalid country code ()"
Aug 20th, 2009
Hi all,
I have problems upgrading my 1131 Autonomous to LWAPP to be used towards an WLC 4402.
I have used the Upgrade tool and tried with 2 different versions of the Cisco recovery image on 2 different 1131 hardware boxes.
The upgrade seeems to go ok all the way. It downloads the image, reboot, connects to our WLC and starts the download of latest image from the WLC.
But at next restart it won't connect.
Version of WLC is 4.2.130. WLC is accepting self signed certs from AP's.
The WLC has 8 functioning AP's connected. These AP's where LWAPP from start though.
The WLC gives me the following errors when running debug:
Thu Aug 20 12:28:56 2009: 00:25:84:90:f7:f0 Received LWAPP JOIN REQUEST from AP 00:25:84:90:f7:f0 to 06:0a:10:10:00:00 on port '1'
Thu Aug 20 12:28:56 2009: 00:25:84:90:f7:f0 AP AP0024.976f.8620: txNonce 00:1B:D5:68:D0:20 rxNonce 00:25:84:90:F7:F0
Thu Aug 20 12:28:56 2009: 00:25:84:90:f7:f0 LWAPP Join Request MTU path from AP 00:25:84:90:f7:f0 is 1500, remote debug mode is 0
Thu Aug 20 12:28:56 2009: 00:25:84:90:f7:f0 Successfully added NPU Entry for AP 00:25:84:90:f7:f0 (index 9)
Switch IP: xxx.xxx.1.101, Switch
Port: 12223, intIfNum 1, vlanId 0
AP IP: xxx.xxx.144.55, AP Port: 63586, next hop MAC: 00:00:0c:07:ac:01
Thu Aug 20 12:28:56 2009: 00:25:84:90:f7:f0 Successful transmission of LWAPP Join Reply to AP 00:25:84:90:f7:f0
Thu Aug 20 12:28:56 2009: 00:25:84:90:f7:f0 spam_lrad.c:1766 - Operation State 0 ===> 4
Thu Aug 20 12:28:56 2009: 00:25:84:90:f7:f0 Register LWAPP event for AP 00:25:84:90:f7:f0 slot 0
Thu Aug 20 12:28:56 2009: WARP IEs: (12)
Thu Aug 20 12:28:56 2009: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
Thu Aug 20 12:28:56 2009: 00:25:84:90:f7:f0 Register LWAPP event for AP 00:25:84:90:f7:f0 slot 1
Thu Aug 20 12:28:57 2009: 00:25:84:90:f7:f0 Received LWAPP CONFIGURE REQUEST from AP 00:25:84:90:f7:f0 to 00:1b:d5:68:d0:23
Thu Aug 20 12:28:57 2009: 00:25:84:90:f7:f0 AP 00:25:84:90:f7:f0: Invalid country code ().
Thu Aug 20 12:28:57 2009: 00:25:84:90:f7:f0 Updating IP info for AP 00:25:84:90:f7:f0 -- static 0, xxx.xxx.144.55/255.255.255.0, gtw
xxx.xxx.144.1
Thu Aug 20 12:28:57 2009: 00:25:84:90:f7:f0 Updating IP xxx.xxx.144.55 ===> xxx.xxx.144.55 for AP 00:25:84:90:f7:f0
Thu Aug 20 12:28:57 2009: 00:25:84:90:f7:f0 AP 00:25:84:90:f7:f0 not allowed to join. Regulatory Domain check failed.
Allowed regulatory domain:
802.11bg:-E 802.11a:-E
Thu Aug 20 12:28:57 2009: 00:25:84:90:f7:f0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:25:84:90:f7:f0 slot 0
Thu Aug 20 12:28:57 2009: 00:25:84:90:f7:f0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:25:84:90:f7:f0 slot 1
Thu Aug 20 12:28:57 2009: 00:25:84:90:f7:f0 Deregister LWAPP event for AP 00:25:84:90:f7:f0 slot 0
Seems like the AP is not sending a Country code at all "Invalid country code ()."
The WLC and AP's are in different countries (Sweden and Belgium), but that has been prepared for in the WLC which accept both.
Any ideas?
Overall Rating: 5 (1 ratings)
dgohain Thu, 08/20/2009 - 13:35
try enabling the country code on the WLC for sweden and belgium
It will be in the wireless page of the WLC
robert-olsson Thu, 08/20/2009 - 22:54
Both BE and SE is enabled in this WLC.
But from the WLC debug I can't see that the AP is even presenting it's country code to the WLC.
Leo Laohoo Mon, 08/24/2009 - 14:53
What WLC firmware are you using?
From the AP, can you ping the WLC's Management IP address?
In enable mode from the AP, can you try the command lwap ap controller ip address .
Hope this helps.
robert-olsson Wed, 08/26/2009 - 23:58
Solved.
I had the errormessage from the beginning... But found it to unlikely...
"Regulatory domain check failed"
The supplier for our Belgian site has delivered a model of AIR-AP1131AG-N-K9, which is a US version.
What I need is AIR-AP1131AG-E-K9 for our European sites.
For you who have run into the same problem, follow this link for more info:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6087/product_data_sheet0900aecd801b901c.pdf
Thanks for the assistance.
Scott Pickles Sun, 08/30/2009 - 15:08
I have also seen the following occur with autonomous APs - you get a unit shipped with a 2.4 radio in one country code and the 5 radio in another country code. This won't keep the AP from joining, but it will shut down whichever radio isn't supported.
Scott
Trending Topics - Security & Network
