08-20-2009 07:27 AM - edited 03-04-2019 05:47 AM
Hi everyone, I have a ISR 3845 to replace a router 3725. On the 3725 I have a ATM 1A-OC3MM that I need to install on the ISR 3845.
Does anyone know if this module works on the 3845 and IOS that I need?
08-20-2009 07:37 AM
Not supported under the 3800
On the 3800 you need NM-1A-OC3-POM along with SFP-OC3-MM
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd80300024.html
HTH,
__
Edison.
