UCCX 7. SQL install
Aug 20th, 2009
I'm installing UCCX 7 with HA and am having trouble with the SQL install. I am using an MSDN cd for SQL 2000, but the install does not work as advertised. Do I need a consumer version of SQL2000 cd or must I purchase the SQL2000 cd from Cisco? Anyone know the Cisco Part No?
Overall Rating: 4 (1 ratings)
matthewpage Thu, 08/20/2009 - 08:31
  • Bronze, 100 points or more
Hi Brandan
You need the Cisco SQL 2000 DVD which you have to order. You cannot just use any SQL server disk. I believe you used to be able to though in the older versions.
The part code i think is CCXIVR-70DB1PS1. That is what is on the box any way.
Matt
brandan.rowley@... Thu, 08/20/2009 - 08:42
Thanks Matt,
That explains it. We didn't need the Cisco disc for version 4. I finally found the Part No if anyone else is looking.
CCXIVR-70DB1PS1 CCX or IVR 7.0 MS SQL 2K Server 1 Processor Software
CCXIVR-70DB2PS1 CCX or IVR 7.0 MS SQL 2K Server 2 Processors Software
