Secondary IP address in the same subnet and EIGRP
Aug 20th, 2009
I have the following config on an L3 switch:
interface Vlan2
ip address secondary
ip address
no ip redirects
EIGRP is running on this switch, and then redistributes in BGP on the edge router. Accessing the secondary IP address from outside the network sometimes fails. I cannot see why.
Any ideas?
johnspaulding Thu, 08/20/2009 - 08:41
How many times a day does it fail? Have you noticed any routing changes? Are you at a remote location and do the route get redistributed into an MPLS cloud? thanks
prakkdangc Fri, 08/21/2009 - 08:06
Thanks John .. turned out to be an IP conflict.
Thanks for the quick response!
