Use Cisco SNMP ping mib
Answered Question
Aug 20th, 2009
Hello, I am trying to use the mib on this page:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8e.shtml
This is the line I am having issues with:
snmpset -c public Router_Source .1.3.6.1.4.1.9.9.16.1.1.1.3.333 octetstringhex “AB 44 76 67”
I can, using a linux server, get to the last part of the command, where I enter my remote ip in hex that I want to ping, but it will not go any further.
Here is what I get:
snmpset -c communitystring routerip .1.3.6.1.4.1.9.9.16.1.1.1.3.333 octetstringhex "AC 18 00 02"
.1.3.6.1.4.1.9.9.16.1.1.1.3.333: Unknown Object Identifier (Sub-id not found: (top) -> AC 18 00 02)
I tried without the quotes and get this error:
snmpset -c communitystring routerip .1.3.6.1.4.1.9.9.16.1.1.1.3.333 octetstringhex AC 18 00 02
18: Bad object type: 0
I have tried with quotes, without quotes, spaces and no spaces. Can someone point out what I'm missing? Thanks.
I removed the community and router ip obviously. Those are present in the command when I try running it.
Correct Answer by Joe Clarke about 7 years 6 months ago
No. net-snmp defaults to SNMPv3. Try:
snmpset -v 1 -c communitystring routerip .1.3.6.1.4.1.9.9.16.1.1.1.3.333 x "AC 18 00 02"
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 08/20/2009 - 09:04
I assume you're using net-snmp. If so, the command is:
snmpset -c communitystring routerip .1.3.6.1.4.1.9.9.16.1.1.1.3.333 x "AC 18 00 02"
dj_oberry Thu, 08/20/2009 - 10:03
I now get this message using that:
snmpset: No securityName specified
I'm guessing that there is an additional setting in the router I need at this point?
Correct Answer
Joe Clarke Thu, 08/20/2009 - 10:05
dj_oberry Thu, 08/20/2009 - 10:14
v 1 failed, but v 2c gets me this, which looks to be right? (Sorry not sure if this is the response I'm needing or if I should get another.)
snmpset -v2c -c communitystring routerip .1.3.6.1.4.1.9.9.16.1.1.1.3.333 x "AC 18 00 02"
SNMPv2-SMI::enterprises.9.9.16.1.1.1.3.333 = Hex-STRING: AC 18 00 02
