CER 1.32 to 7.03A Migration
Aug 20th, 2009
I'm trying to find Cisco docs on how to do this migration. The release notes are good but vague on the DMA process.
What DMA do you use for CER 1.32 to 7.03? Is it the same DMA you use for a migration from CUCM 4.x to 7.0x?
I know the DMA is version specific for CUCM, meaning if going to 6.1 you need DMA 6.1 if going to 7.0x you need DMA 7.0x and if going to 7.1x you need DMA 7.1x.
So for CER 1.32 to 7.03a do i use CUCM DMA 7.0x?
Thanks for any input in advance.
irisrios Wed, 08/26/2009 - 11:40
  • Silver, 250 points or more
All DMA 7.x versions are meant to be used for upgrading to CER 7.x, and all DMA 6.x versions are meant to be used for upgrading to CER 2.x.
