UCCX 7.X HA solution, Is this possible
Aug 20th, 2009
  • Cisco Designated VIP,
    2017 IP Telephony
Guys,
I have a customer who wants to deploy UCCX across different geographic sites for DR purposes. We have informed the customer that this is not supported by cisco. However the customer has come back asking if its possible to have a HA solution in on sit and then a spare "Cold standby solution in another site"
Question is will this work? I cant see how a configuration taken from a HA cluster can be restored to a stand alone server!!!
Overall Rating: 5 (2 ratings)
Jonathan Schulenberg Thu, 08/20/2009 - 10:29
    2017 IP Telephony
Cold standby is supported and documented in the SRND for CCX. This will be discontinued in 8.0 however as high availability over the WAN will be supported at that time. If the customer can wait, I would hold off until 8.0 due out early 2010.
Note that the 8.0 HA model will require very similar bandwidth/delay/jitter/reliability as UCM HA requires. Final documentation has not been released so there are no final numbers yet.
jleon22 Mon, 03/15/2010 - 14:17
  • Bronze, 100 points or more
It looks like the clustering over the WAN did not make it into version 8.0.
Aaron Harrison Mon, 03/15/2010 - 17:15
  • Community Spotlight Award,
    Member's Choice, May 2015
HAoWAN is in 8.0 (possibly worth posting on the Ask the Expert thing Ryan LeFountain is doing at the moment for more info/confirmation).
Some info I've seen:
- Requirements I've seen are 80ms RTT, 3Mb BW (variable based on usage blah blah)
- Support for re-election of a master when the system goes active/active (due to a partitioned cluster during WAN failures).
- Apparently you must select 'WAN' as the deployment type when setting up the second node
- Various other things changed here and there so you can use local resources for each server, have local 'locations' setting etc in CCM.
Aaron
jleon22 Tue, 03/16/2010 - 06:14
Hi Aaron,
I apologize for my inaccurate comment. It was actually our Cisco SE that claimed the feature HAoWAN did not make it in versin 8.0. The release notes for UCCX 8.0 just came out and it does mention this feature.
Thanks Aaron. Stars for you!
