streaming ip cams into VLC
Aug 20th, 2009
Does anyone know of any information anywhere's about streaming video from the new IP cams, specifically the CIVS-IPC-4500 HD cams, into VLC?
Any help much appreciated.
gary-grobe Mon, 08/24/2009 - 14:49
I'm not sure I understand how that would work w/ VLC (v1.0.0). Open a network stream, select the protocol and ip, and then play. There's no such choice for the user, passwd, etc... and how do you expect to authenticate w/ the camera first?
The interface to the HD cams expect you to log in, but there appears to be no option for what IP to send a stream to in the stream settings web interface of the cam either.
Any other ideas there?
Tomas De Leon Tue, 08/25/2009 - 09:52
  • Cisco Employee,
High Definition (HD) IP Camera
As with the SD IP camera example, VLC Media Player can also be used to view the video streams from Channel 1 and Channel 2 from the HD IP camera. Accessing the Video Stream on the HD IP camera requires gathering additional
information from the HD IP Camera. You must access the HD IP Camera via HTTP to gather the following parameters: sessionID, ChannelName for Both Channels.
• Navigate to the Streaming Settings on the Camera web page and get the sessionID parameter from the “URL”
ie. HTTP to HD IP Camera
http://10.1.1.1/home.cs?version=1.0&sessionID=12345678&action=get
• Confirm & Record the Channel Name (s). For Example, "Channel1" or “Channel2”.
URL Location: rtsp://< HD CAMERA IP ADDRESS >/StreamingSetting
StreamingSetting = ?version=1.0&action=getRTSPStream&sessionID=< SESSION-ID >&ChannelID=< 1 or 2
>&ChannelName=< Channe1 or 2>
ie.
rtsp://10.1.1.1/StreamingSetting?version=1.0&action=getRTSPStream&sessio...
Channel1
In the example above,
‣ 10.1.1.1 is the HD Camera IP Address.
‣ 12345678 is the sessionID from the URL. This will be different for each new session.
‣ Channel ID is “1” and ChannelName is “Channel1”
Simply Use the RTSP URL above in the Media Resource Locator (MRL) field in VLC
radiantmachines Tue, 09/08/2009 - 14:22
Howdy,
I have tried to the your suggested steps and am unable to play the video streams using VLC 1.0.1 for Ubuntu Linux or Windows XP.
I am certain that I was able to get the correct session-id. I used your method of finding it manually in the URL, and in addition to that I wrote a Python script to find it for me.
Python script (needs lxml library) : http://pastebin.com/f12201bfd
The Python script also allowed me to grab the config XML for my cam which can be found at: http://pastebin.com/f7a8901ed
I ran vlc with this command:
vlc "rtsp://192.168.5.146/StreamingSetting?version=1.0&action=getRTSPStream&s..." > /tmp/vlc-error 2>&1
the resulting output can be found at : http://pastebin.com/f2b1cef2e
*important note. the original error log contained thousands of the following string
"number of reference frames exceeds max (probably corrupt input), discarding one"
starting like
"VLC media player 1.0.1 Goldeneye
[0x8ba5140] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
insane cropping not completely supported, this could look slightly wrong ...
FMO not supported
reference overflow (pps)
B picture before any references, skipping
decode_slice_header error
I have trimmed them out show the more salient parts of the log.
Could you please offer advice.
