Incorrect time on phones in CCME 7.1
Aug 20th, 2009
Hello everyone,
we have a situation where the time displayed on teh phones is one hour behind the time dispplayed in the GUI on CCME 7.1 for the system time. ANy suggestions on where the phones might be picking up the wrong time from?
Thanks in advance! All replies rated.
Overall Rating: 4 (1 ratings)
Rob Huffman Thu, 08/20/2009 - 11:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi angel,
This is not an uncommon issue that should be quite fixable :)
Troubleshooting Incorrect Time Stamp on IP Phones in Cisco Unified CME
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html#wp1053981
After changing the time-zone setting you could follow these steps.
Usage Guidelines
This command works with the vendorConfig section of the Sep*.conf.xml configuration file, which is read by the phone firmware when the Cisco IP Phone is booted up. Certain phones, such as the Cisco Unified IP Phone 7906 , 7911, 7931, 7941, 7942, 7945, 7961, 7962, 7965, 7970 , 7971, and 7975, obtain Coordinated Universal Time (UTC) from the clock of the Cisco router. To display the correct local time, the time display on these phones must be offset by using this command.
This command is not required for Cisco Unified IP Phone 7902G, 7905G, 7912G, 7920, 7921, 7935, 7936, 7940, 7960, or 7985G.
For changes to the time-zone settings take effect, the Sep*.conf.xml file must be updated by using the create cnf-files command and the Cisco IP phones must rebooted by using the reset command.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_t1ht.html#wp1023398
under the telephony-service -
no create cnf-files
create cnf-files
Then reboot the individual phones :)
This was really covered nicely by Paul in this thread :)
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified Communications and Video&topic=General&CommCmd=MB?cmd=display_location&location=.2cbf1665/0
Hope this helps!
Rob
angel-moon Thu, 08/20/2009 - 12:11
Thanks Rob,
when I enther the command create cnf-files the router responds with
Creating CNF files CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
Any ideas on that?
