Sending email from outside and SMTP Authentication
Aug 20th, 2009
Hello all,
I was told earlier that company users can send emails from outside using either VPN or SMTP authentication, is there a third way to do this? if yes, please mention it...
I also require some information on how to configure SMTP authentication...
your help is highly appreciated...
jowolfer Thu, 08/20/2009 - 17:40
I believe you're reffering to the ESA C-Series appliance, but you've posted in the WSA forum.
I'm moving this posted to the appropriate forum, please let me know if I've misunderstood your post.
TheEncryptedSpi... Thu, 08/20/2009 - 19:00
yes, you are right, I meant the C-series, thanks for shifting the case to the appropriate forum...
Andrew Wurster Thu, 08/20/2009 - 22:35
thanks josh for directing! from our knowledgebase:
External users using LDAP SMTPAUTH to authenticate and relay mail:
you can also consult your asyncos advanced user guide:
LDAP Queries > Configuring AsyncOS for SMTP Authentication
good luck!
