No Access to 3750 Console
Aug 20th, 2009
I'm using Secure Crt for console access to all cisco devices. This morning i can no loger communicate with cisco 3750's through console port, i tried on 3 different 3750's with same result. That same secure crt set up worked fine with firewall and switches. Any clues of what is wrong? Thx.
Lucien Avramov Thu, 08/20/2009 - 12:45
  • Red, 2250 points or more
Check the cable connection, try putty or hyperterminal.
Perhaps it may be also a problem on your pc, reboot that one as well.
On hyperterminal click on DEFAULT for the serial connection settings.
John Blakley Thu, 08/20/2009 - 12:49
  • Purple, 4500 points or more
Make sure that you're actually at the default speed of 9600 baud. Try different speeds etc.
HTH,
John
glen.grant Thu, 08/20/2009 - 12:57
If you have rebooted since using it on the firewalls and you are using a usb connector check to make sure the pc didn't use a different com port when it rebooted.
nguyenvinnie Thu, 08/20/2009 - 15:19
undocked the laptop Secure Crt re-acted funny :-), I tried using the Hyperterm and it works fine. Thanks everyone.
