voice translation profile
Aug 20th, 2009
I am created simple voice translation profile to strip 0022 country code and replace it with 0.
voice translation-rule 1
rule 1 /0022\(.*\)/ /0\1/
I have applied to both voice port and dialpeer pots as outgoing profile. I have tested with test voice translation rule 1. But, when the call hits the voice gw, and is routed out to pstn via ISDN, I see number being sent without leading 0. The call is not accepts by PSTN and dropped.
Any idea how to fix it.
cheers
Muhammad
Rui Carlos Antunes Fri, 08/21/2009 - 06:42
Can you attach the configuration of the dial-peers?
Also, can you make sure that the outbound call is using the dial-peer that has the translation profile (using "debug voice ccapin inout" during the call setup)?
