Document not reloading
Aug 20th, 2009
I upload an xml file into the document repository via the web interface. It overwrites the old xml file by the same name. The script does not read the new xml file, it reads the old file.
Is this a feature or bug, and how do I get it read the new file without restarting the node manager?
uccx 7.0(1)SR03_Build011
joesnyde Fri, 08/21/2009 - 08:27
  • Cisco Employee,
Within the script, does the xml file name appear correctly? The name should be exactly as the the file name. Also after uploading the xml file to the document repository, did you refresh the script, even better to reload. You may need to refresh the application as well, but doubt that will be needed.
steakandeggs Fri, 08/21/2009 - 11:06
The name appears correctly. It is specified thus: DOC[customer\animap.xml]. Weirdly, if I change the location or name of the file, the script will load that just fine. But once loaded, always loaded. I found that even restarting the node manager and even rebooting the server (there is only one uccx server) changes nothing.
