connecting two internal networks in un asa
Aug 20th, 2009
I have a ASA5510, with a segment in the interface inside but I need to configure other segment new and Both segments have to communicate, as I do ?
Overall Rating: 5 (3 ratings)
ivanguzman Fri, 08/21/2009 - 05:54
Hi Andrew,
I configure another interface on the ASA, the new interface must have a security level lower than the inside.?
how can I enable the new interface to communicate with the inside.?
hschaefers Fri, 08/21/2009 - 06:00
I am in the same situation. I am in need of getting a security levl 100 to comunicate with a 75 on diff interfaces.
Mine keeps erroring on the NAT rule stating that there isnt' any pool.
Can some one shed some light on the suggested approach for configuration so I can verify that the I have the correct configuration?
1.) I know the NAT rule needs to be on the higer seccurity.
2.) I know you need a Permit ACL on the lower interface to permit access inbound.
It can have the same security level if you want - depending on it's purpose, I generally give any other interfaces a lower security level, say 50.
What I then do - is make a NAT exempt from the inside to the new interface (this is bi-directional)
Once the NAT is working ok, I then write an ACL for any traffic that originates from the new interface to the inside.
hschaefers Fri, 08/21/2009 - 06:13
Do you put that exempt rule on the Higer security interface or make a seperate one for each lower interface?
generally what I do is:-
1) Create an inside to new interface ip access-list.
2) attache the acl to the nat (inside) 0 config
3) Create an new interface to inside ip access-list
4) attach the acl to the nat <> 0
Then let the traffic flow - in both directions, when you have no hits on the acl from the new interface to the inside - you know your inside NAT exampt rule is bi-directional (sometimes it does not work straight away)
Sometimes I leave them in there - especially, when I need to make the new interface part of a VPN - then the exmpt acl just gets expanded.
ivanguzman Fri, 08/21/2009 - 06:28
the configuration would be as follows is correct or I'm missing some parameter?
interface Ethernet0/1
nameif inside1
security-level 100
ip address
interface Ethernet0/2
nameif inside2
security-level 75
ip address
access-list ACL_IN2 extended permit ip 172.16.13
static (inside,inside2) netmask
access-group ACL_IN in interface inside
access-group ACL_IN2 in interface inside2
that would be one way of doing it, I would
access-list no-nat1 permit ip
nat (inside1) 0 access-list no-nat1
access-list no-nat2 permit ip
nat (inside2) 0 access-list no-nat2
The above allows you to expand the nat-exemption the more interfaces you have.
