VG224 Redundancy - Loopback vs BVI
struttob
We're going to be deploying 20-30 VG224s at each of our hospitals to support patient room analog phones. We've got an IPTel services block consisting of 2 4948's L3 off of the core. L2 trunk and L3 eigrp adjacency (eigrp) between the 2 4948's. We were initially going to do redundant links on the VG224's with EIGRP & loopback on the VG224 but I recently ran into a (non-cisco) article talking about configuring IRB on the VG224 to create a bridge group and BVI on the VG224 to assign the IP address to. To me it seems simpler & cleaner than configuring eigrp (with stub plus distribute list w/ prefix list, etc) on hundreds of vg224's across the org.
Has anyone configured vg224 redundancy in this manner? Good, bad or indifferenct experience? Opinions? We can't seem to get any solid opinion out of Cisco on the matter.
Thanks !
6 Replies 6
hadbou
Level 5
Level 5
For the Loopback address, you can enter a Loopback address. VG224 does not support EIGRP, it does seem to support RIP and OSPF. RIP could cost you a subnet to have a loopback (not sure if v2 is supported). So please make sure it.
Um, the VG224 most definitely DOES support EIGRP. That is the way that we have redundancy configured initially (2 routed links + loopback, EIGRP stub connected).
The real question was should this be done via L3 as we're doing or does it make more sense to take a L2 approach to redundancy with 2 links, bridge group & BVI on VG224..
Thanks !
kfav
I was just attempting to configure this using a BVI but am seeing unacceptable results. Perhaps someone can help:
On my VG224:
interface FastEthernet0/0
no ip address
no ip proxy-arp
duplex auto
speed auto
bridge-group 1
interface FastEthernet0/1
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address x.x.x.135 255.255.255.224
ip route 0.0.0.0 0.0.0.0 x.x.x.132 (VLAN Gateway on 3750X stack)
bridge 1 priority 65535
bridge 1 protocol ieee
bridge 1 route ip
On 3750X:
interface GigabitEthernet1/0/1
switchport access vlan 128
switchport mode access
switchport nonegotiate
interface GigabitEthernet2/0/1
interface Vlan128
ip address x.x.x.132 255.255.255.224
no ip redirects
no ip proxy-arp
spanning-tree mode rapid-pvst
When I start running pings from VG224 to 3750X I drop maybe 5/10000 packets and receive the following error:
*Mar 30 01:03:54.387 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host x.x.x in vlan 128 is flapping between port Gi1/0/1 and port Gi2/0/1
I had this same problem with the mac flapping after setting up irb.  You need to assign a mac address to the bvi interface.  A website explaining the issue http://nets.ucar.edu/nets/devices/routers/cisco/bvi-config.htm
Thank you for taking the time to report this.
I've rated your post.
You should turn on the locally administered bit in the first byte of the mac address. 00000010
Don't turn on the multicast bit. 00000001
eg don't use 01 or 03 etc. Do use 02, F2, FE, 12 etc
We used 0200.0224.0224,
0123.0123.0123 did not work.
