OID for power supply fan
Answered Question
Aug 20th, 2009
Hi everyone,
Is there a way to monitor the fan on the PS via snmp? any oid for this.
from sh env:
Power Supply 1 is present.
Fan status: Warning - failure
Input Voltage status: normal
DC Output Voltage status: normal
Power Supply 2 is present.
Fan status: normal [[[[[-----am interested in this fan!!!
48V Power Supply 3 is not present.
48V Power Supply 4 is not present.
Fan 1 Failed [[[[--------not this fan
Board Temperature: normal.
Appreciate your replies. Thanks.
Correct Answer by Joe Clarke about 7 years 5 months ago
There is no specific object for the PS fan in this version of IOS. However, it does support the ciscoEnvMonSupplyStatusTable. The ciscoEnvMonSupplyState object will give you the overall status of the power supply.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 08/20/2009 - 19:50
What type of device is this, and what version of code is it running?
Correct Answer
Joe Clarke Thu, 08/20/2009 - 20:39
tfontano Thu, 08/20/2009 - 21:54
Thanks Joe. Will have to contend with this. Appreciate your quick response.
tfontano Thu, 08/20/2009 - 20:03
Got this object, caemSupplyFailedComponent, from CISCO-ACCESS-ENVMON-MIB, but i'm not getting the response from an snmpwalk that I expect. Still doesn't indicate the failure of the fan on the PS.
