ACS Replication
Aug 20th, 2009
I have 2 ACS boxes (Cisco Secure ACS 4.0 X solution engine 1113 appliance).Is there any way i can replicate the configuration of both the there any way or we manually need to do config replication (Both ACS reachable to each other as well as to ACS client).
Please share any document in regards with this if available and possible.
sameermunj Thu, 08/20/2009 - 21:35
Thanks for the quick reply.
Actually we tried doing the replication and it was working fine.we removed the setup and shifted to diffrent location and reachability was same but we are getting the error
shared-secret mismatch
now the replication is not happening and we are surprised with this behaviour as no config change done but its just change of location (Floor shift)
Jagdeep Gambhir Fri, 08/21/2009 - 01:22
In acs do you see 127 IP address for aaa server? Make sure shared secret is same on both ends.
Do rate helpful posts
sameermunj Fri, 08/21/2009 - 01:31
Shared secrtes are same as its just change of location.
127 ip address does not exist for aaa server.
sameermunj Fri, 08/21/2009 - 22:27
Thanks for the reply.
when i click for the above URL its showing==The Page You Have Requested Is Not Available
can you please attach the pdf for my reference..
