Music-On-Hold is not working at internal call
Answered Question
Aug 20th, 2009
Hi all,
I already cange the MOH file at Telephony-service.
After that change, all of the call coming from outside can hear new MOH but internal call cannot hear that new MOH.
Is there any command to add?
If any, anyone pls guide me.
Correct Answer by Juan Carlos Ari... about 7 years 6 months ago
Hi Maung,
As you said telephony-service I suposse you are running a CallManager Express, if that is, you should configure multicast, like this:
telephony-service
moh music-on-hold.au
multicast moh 239.0.1.1 port 2000
Try it and see if this is the solution.
Hope this helps,
JC Arias
Overall Rating: 3 (1 ratings)
Correct Answer
Juan Carlos Ari... Thu, 08/27/2009 - 10:40
Hi Maung,
telephony-service
Hope this helps,
JC Arias
