how to find the nvram details from cisco 4507 switches
Aug 21st, 2009
Dear Team,
Please provide the info to know the below details:
Available NV RAM, Used NV RAM, Available Flash, Used Flash
phani
Giuseppe Larosa Fri, 08/21/2009 - 02:01
  • Hall of Fame,
    Founding Member
Hello Phani,
you can use
dir nvram:
dir nvram:
Directory of nvram:/
512 -rw- 7422 startup-config
513 ---- 57 private-config
514 -rw- 7422 underlying-config
1 ---- 0 rf_cold_starts
2 ---- 149 persistent-data
3 -rw- 0 ifIndex-table.gz
524280 bytes total (513677 bytes free)
and
dir /all to find all filesystems on the flash(es)
Hope to help
Giuseppe
phaniraj01 Fri, 08/21/2009 - 02:09
Thanks for your quick reply,
we have only enable 10 previleges.
is there any other sh command
thanks,
phnai
