EEM applet for "no shutdown" of the external interface
Aug 21st, 2009
I needed 2 applets for failover;
1)one to down the interface when it finds the DNS interface down.
2) 2nd to Up the interface when it finds the DNS interface up.
Now, The "down applet" works fine, but "Up applet" doesn't.
Can you please check what mistake am i making? Also, If I keep one IP SLA for both EEM applets (for up and down).Will that be ok?
ip sla 443
tcp-connect 443 control disable
frequency 60
ip sla schedule 443 life forever start-time now
track 443 rtr 443 reachability
delay down 60 up 60
event manager applet server_up_example
event track 443 state up
action 01.0 syslog msg "TCP service is available"
action 02.0 cli command "enable"
action 03.0 cli command "config t"
action 03.0 cli command "interface gig0/0"
action 04.0 cli command "no shut"
action 05.0 syslog msg
OUTPUT (somthing like this. It doesn;t Up the interface. while for down it works fine)
Round Trip Time (RTT) for Index 1
Type of operation: icmp-echo
Latest RTT: 1 ms
Latest operation start time: 10:02:15.190 UTC Thu Aug 20 2009
Latest operation return code: OK
Number of successes: 0
Number of failures: 4
Operation time to live: Forever
dexterslab Fri, 08/21/2009 - 04:48
I found the problem. I was making it down using cli command for testing purposes. When i tried with physical wire plug in and out, it start working fine.
Joe Clarke Fri, 08/21/2009 - 06:57
The actual state of the IP SLA collector isn't as important as the state of the tracked object. Even if you shutdown an interface manually, if the collector cannot reach, then it will go down, and 60 seconds later, so should the tracked object.
Typically, when I'm testing this kind of thing, I use a black hold route. For example:
ip route null0
This way, I don't lose other connectivity, and I can still check whether or not the IP SLA collector, EOT, and EEM functions are working.
And, yes, one collector, and one tracked object is fine for what you want to do.
