Leaking connected routes into VRF Routing table
Hitesh Vinzoda
Level 4
Level 4
In my campus, we have deployed vrf lite and is working fine for a situation where we have to leak the routing table between vrf and Global routing table on a switch where i had one arm in VRF and other in global routing table.
I had another situation in which i have to leak the connected vlan subnets of global routing table to vrf routing table. I tried it with static routes but i didnt seems to work.
Hitesh Vinzoda
VRF-select allows you to have an interface in a VRF in addition to the GRT.
So if it's supported, I would remove the BGP config and configure both VLAN interfaces with VRF select so both interfaces will be seen on the GRT and the VRF:
int VLAN 70
ip vrf select source
ip vrf receive vendor
int VLAN 10
So no need for specific routes to join the VLAN but only for the remote subnets
Laurent.
23 Replies 23
Peter Paluch
Hitesh,
Can you perhaps post your configuration here, or at least the command you have tried that has failed? You are saying - 'it didn't seem to work'. Can you be more specific about that?
Best regards,
Peter
Hi Peter,
In first case, where it happens to work is i had a switch in which its one interface is configured as VRF RED and other interface of the switch is connected to firewall (which is in global routing domain). What i have done is configured static route for each VRF subnet in VRF domain and it results in routing entry of VRF routes in Global routing table. Also i had Global routing prefixes are configured via Static routes in VRF routing table. e.g.
Switch Interfaces
10.0.56.5 255.255.255.252 ( VRF RED) Int gi1/0/1 ( Connected to VRF Interface on Core switch)
10.0.56.129 255.255.255.128 Fa1/0/1 connected to Firewall)
Routes configured on switch are:
ip route 10.0.56.5 255.255.255.252 gi1/0/1
ip route vrf RED 10.0.56.128 255.255.255.128 fa1/0/1 10.0.56.130
This config works as it seems that the Switch is sitting in between VRF and Global routing table and allowing to enter the next hop ip address.
My problematic situation is say for example switch in above case is also having some connected vlan interfaces in global routing domain. and i enter the commamds as follow
ip route vrf RED 10.0.110.0 255.255.255.0 vlan 110 10.0.110.1
it doesn't ping, although it is present in VRF RED's routing table across the VRF domain via OSPF and reverse route entry in global routing table entry is also present configured via static routes.
Please let me know if you want further inputs.
I roamed around the forums and found that we can import the routes from global routing table to vrf via "BGP Support for ipv4 Prefix Import".
I can see the prefixes in switches vrf routing table as "B" via BGP and redistributed across the vrf ospf domain.
but still i doesnt pings from switch's global interface to interface in vrf.
Link for reference
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc2273a/1
Hitesh Vinzoda
Hi Hitesh,
if 10.0.110.1 is the ip address of the switch itself, it's expected not to work.
You have two solutions:
- BGP import v4 route as describe in your link reference. You first need to redistribute your VLAN into BGP
- VRF select: http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Service%20Providers&topic=MPLS&topicID=.ee8558c&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd353fc
You are talking about switched so not sure if those features are supported.
Laurent.
Hi Laurent,
Thanks for reply.
I have done it as illustrated in the post for redistribution vlan into BGP and than into OSPF instance of VRF. the Vlan subnets are propagated down the VRF. But could you help me out in leaking VRF routes in global routing table, Shall i proceed with the static routes as illustrated above...?
Im testing this setup on 3750 12.2 IP services, if successfull will be deployed on 4507R 12.2(50)SG1.
TIA
Hitesh Vinzoda
int VLAN 70
int VLAN 10
Laurent.
Laurent,
Wow. I did not know about this until you pointed it out. Thank you very much indeed!
Best regards,
Peter
Hitesh,
I gave it a few tries. The fact is that in a VRF, I can't define a static route pointing just to a global LAN interface because the IOS complains that it is not a point-to-point interface and therefore it needs a next-hop address. However, obviously, the BGP using the Prefix Import functionality is able to do it.
The solution with the BGP Prefix Import is probably the most clean here. However, you are saying that despite the routes being present in the VRF, you can not ping them.
I have configured three routers in a row called PC, R1 and R2. The network between PC and R1 is 192.168.12.0/24, the network between R1 and R2 is 10.0.23.0/24. This is a configuration that works for me:
On PC:
hostname PC
interface FastEthernet0/0
ip address 192.168.12.1 255.255.255.0
no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.12.2
R1:
hostname R1
ip vrf V1
rd 1:1
import ipv4 unicast map RM_Conn
interface Loopback0
ip address 10.255.255.1 255.255.255.255
ip ospf 1 area 0
ip vrf forwarding V1
ip address 192.168.12.2 255.255.255.0
no shutdown
interface FastEthernet0/1
ip address 10.0.23.2 255.255.255.0
ip ospf 1 area 0
no shutdown
router ospf 1
redistribute static subnets
router bgp 64512
redistribute connected
ip route 192.168.12.0 255.255.255.0 FastEthernet0/0
route-map RM_Conn permit 10
On R2:
hostname R2
interface Loopback0
ip address 10.255.255.2 255.255.255.255
ip ospf 1 area 0
ip address 10.0.23.3 255.255.255.0
ip ospf 1 area 0
no shutdown
Note that on R1, I have a static route in global table pointing to the VRF network between PC and R1 and I redistribute it into OSPF so that R2 knows about it.
Now, from PC, observe these pings:
PC#ping 10.255.255.1 ! Pinging the lo0 on R1
Sending 5, 100-byte ICMP Echos to 10.255.255.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
PC#ping 10.0.23.2 ! Pinging the Fa0/1 on R1
Sending 5, 100-byte ICMP Echos to 10.0.23.2, timeout is 2 seconds:
PC#ping 10.0.23.3 ! Pinging the Fa0/1 on R2
Sending 5, 100-byte ICMP Echos to 10.0.23.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/8 ms
Here, I am pinging two directly connected interfaces on R1 - the lo0 and the Fa0/1. I am also pinging the Fa0/1 on R2 to test the reachability beyond R1. As you can see, the pings are successful.
PC#ping 10.255.255.2 ! Pinging the lo0 on R2
Sending 5, 100-byte ICMP Echos to 10.255.255.2, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
The last ping does not work because on R1, the VRF V1 does not contain route to lo0 on R2 - I have not imported nor defined it, so it is normal that it does not work.
Can you compare your configuration with this one?
Best regards,
Peter
Hi Peter,
I will give a try with the config you just posted. can you please tell me what we are matching under route-map in R1's config?
is it prefixes or interfaces..?
Hitesh Vinzoda
That route-map is empty and works simply as "permit any" for the sake of simplicity here.
If you were to implement a selective route-map, you should use a prefix list or an ACL in the route-map. I am not sure if the route-map can refer to interfaces because it basically filters networks that are present in the BGP database. Give it a try :)
Best regards,
Peter
Hi Peter,
As i m at home i dont have access to Lab equipments. but the config looks this below and attached is the topology for your reference
ip vrf vendor
import ipv4 unicast map GLOBAL
router bgp 1
redistribute connected route-map CONNECTED_BGP
address-family ipv4 vrf vendor
interface vlan 110
ip address 10.0.110.1 255.255.255.0
ip prefix-list GLOBAL permit 10.0.110.1/24
match interface vlan 110
route-map GLOBAL
match ip address prefix GLOBAL
int vlan 70
ip vrf forwading vendor
ip address 10.0.70.4 255.255.255.0
router ospf 10 vrf vendor
network 10.0.70.4 255.255.255.0 area 0
ip route 10.0.70.0 255.255.255.0 vlan 70
ip route 10.0.255.1 255.255.255.0 vlan 70 (interface down the vrf)
TIA
Hitesh Vinzoda
Hitesh,
Can you please also describe where are the PCs located when you are trying to do that ping, and what exact IP address are you trying to ping? I am trying to visualize the entire path from the PC to the destination IP and back to the PC.
Best regards,
Peter
Im trying with extended ping from source as vlan 110 on vrf switch (ref Diag) and destination address as 10.0.255.2 ( in vrf)
Hitesh Vinzoda
Hi Peter and Laurent,
After comments from both of you. I was able to successfully ping the vrf interface from GRT. The functional config is posted below,
Many thanks to both of you for helping me on this issue. One more question before we end this discussion. My vlan 110 is in GRT and is functional and i m going to change it as suggested by Laurent (ip vrf receive vrf-name). I think that it is not going to impact any connectivity issues for vlan 110 in GRT. please advice
Hitesh Vinzoda
Functional config
ip routing
ip vrf SAS
rd 100:1
vlan 70,109-110,200,251
interface GigabitEthernet1/0/2
interface Vlan1
no ip address
shutdown
interface Vlan70
ip vrf forwarding SAS
ip address 10.4.70.4 255.255.255.0
interface Vlan110
ip vrf receive SAS
ip address 10.4.110.1 255.255.255.0
router ospf 10 vrf SAS
log-adjacency-changes
redistribute connected subnets
network 10.4.70.0 0.0.0.255 area 0
IDC-TEST#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/24 is subnetted, 1 subnets
C 10.4.110.0 is directly connected, Vlan110
IDC-TEST#sh ip route vr
IDC-TEST#sh ip route vrf SAS
Routing Table: SAS
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 10.4.70.0/24 is directly connected, Vlan70
C 10.4.110.0/24 is directly connected, Vlan110
O 10.4.255.0/30 [110/2] via 10.4.70.2, 00:03:27, Vlan70
IDC-TEST#sh ip route sta
IDC-TEST#sh ip route static
IDC-TEST#
IDC-TEST#ping vrf SAS
Protocol [ip]:
Target IP address: 10.4.255.2
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.4.110.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.4.255.2, timeout is 2 seconds:
Packet sent with a source address of 10.4.110.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
IDC-TEST#
Hi Hitesh,
I am glad you got it working. If it works for you I would personally say that you can go with it but as I do not have enough experiences with the VRF Source Select feature I would like ask Laurent to give his final opinion here.
Best regards,
Peter
