Restricting Remote Access VPN
Answered Question
Aug 21st, 2009
How can i limit Remote Access VPN users, only to a pariticular ip address in may inside network, say 10.10.10.1
Thank you.
Correct Answer by jason.espino about 7 years 11 months ago
If you have an ASA you can simply create a new ACL defining the single inside host to communicate to the network/pool used for the Client VPN users.
You can apply the vpn-filter to the group-policy however doing so all users using that group-policy will inherit that vpn-filter and be restricted to the traffic you have defined within the filter ACL.
If you wish to restrict access for a specific user you can apply that same vpn-filter for that specific user within the user attributes. This filter would not affect connectivity for all of the users connecting to the same group-policy only the user bound to the filter.
Overall Rating: 5 (2 ratings)
You have multiple options:-
1) Write an ACL that is applied to the VPN client.
2) Allow them all access - and write an acl to be applied to the outbound direction of your inside interface
3) Write an ACL for that 1 device and configure is for split tunneling.
4) Assign a dynamic ACL upon connection (this requires an ACS)
HTH>
kwillacey Fri, 08/21/2009 - 08:54
  • Bronze, 100 points or more
You can also try using a vpn-filter which you apply to the group policy. hth
Correct Answer
jason.espino Fri, 08/28/2009 - 23:45
shijomon scaria Sat, 08/29/2009 - 00:25
Thank you very much jason, i will go for the first option, that will do magic for me..........
Thakns for all who responded on ma query...
Shijo.
ray_stone Mon, 08/31/2009 - 00:00
I have configured Remote VPN on outside interface for outside users. Now I want to allow only few IP's to access the Remote VPN so for this, what configuration is required. Pls expain an example if possible.
