UCCX 5.0 - Backup stuck in Initializing
Aug 21st, 2009
When I try to perform a manual backup on UCCX 5.0, it gets stuck in "Initializing".
I don't get any BACKUP_FAIL error code. It just gets stuck in that cycle...
(See attachment MCVD.log for the log messages)
Any ideas?
Thanks in advance.
Overall Rating: 4 (1 ratings)
tim.moomaw Mon, 08/24/2009 - 07:01
I know I had a similiar issue with UCCX 7.0(1) and had to apply a SR which addressed the problem. Not sure if there is any relevant 5.0 SR fix...
Rui Carlos Antunes Wed, 08/26/2009 - 05:31
Hi. Thanks for the reply.
Can you tell us what was the UCCX 7 SR that you used to solve this issue?
After your post, we verified that we have a customer, with UCCX 7.0(1)Build186, with the same problem.
Thanks for your help.
