SSL fails to enroll with MS CA using SCEP.
When I try to enroll to get SSL certificate using SCEP I receive a message
R1(config)#crypto ca authenticate ca
Certificate has the following attributes:
Fingerprint MD5: D6E7527B 9BAFF7D3 5631CE4D 2A5BA341
Fingerprint SHA1: 67C695F8 B9BE93A9 8769947C FC3E3C9C 95B93B30
% Do you accept this certificate? [yes/no]: yes
Trustpoint CA certificate accepted.
R1(config)#
R1(config)#crypto ca enroll google
% You must authenticate the Certificate Authority before you can enroll with it.
Why? I have already authenticate CA!
Thanks.
Andrea
sadbulali Thu, 08/27/2009 - 05:30
  • Bronze, 100 points or more
Are you trying to configure multiple CAs (trusted roots) using SCEP ? Verify the CA is enrolled already or not with this command show crypto key mypubkey rsa.
