Not able to login
Aug 21st, 2009
Hi Team
we are getting this error while login into the LMS
LMS 2.6 on windows server 2003, and getting the below error while logging,
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request
1)Cheked the SSL ports, it is checked
2)Reset the CASUSER password
3)Checked the services.msc ,plse find the snapshot of the same.
4)NMSROOT\bin\Perl NMSROOT\bin\
i have tried all these things but no luck
Plse provide the solution on this
Joe Clarke Fri, 08/21/2009 - 06:51
Post the output of the command:
pdreg -l Apache
As well as the NMSROOT\MDC\etc\regdaemon.xml and NMSROOT\lib\classpath\
Joe Clarke Fri, 08/21/2009 - 23:08
The command is hanging which means there is a process failure. Wait untilvthe command returns then post the output as well as the output of the pdshow command. A process failure can cause pd* commands to hang for up to an hour after Daemon Manager is restarted.
Joe Clarke Sat, 08/22/2009 - 09:15
This installation is very badly damaged. Somehow Apache is no longer a registered daemon with Daemon Manager. On top of that, DCR is failing to properly initialize. Essentially, even if you could login to LMS, nothing would work.
If you have a known good file system and registry backup (i.e. one taken when LMS was working) I recommend you install that. Else, the safest course of action is a reinstall of LMS from scratch. Then if you have a known good data backup of LMS, you can restore that
vaibhav-g Sun, 08/23/2009 - 01:39
Hi Clark
thanks a lot for the solution, could you just let me know where we can check/find the known good file system and registry backup.
Joe Clarke Sun, 08/23/2009 - 06:42
This is something you or your server administrators would have. This is not something done my LMS. This assumes you're using some kind of system backup software.
