Can't connect with Anyconnect client on linux
Aug 21st, 2009
i have question
I've installed anyconnect client on the linux desktop regarding the installation requirements
however when I try to connect, after the login prompt i recieve :
Connecting ...
Checking for ...
Unable to establish VPN
Thnaks for your answer
Collin Clark Fri, 09/11/2009 - 07:04
What does the log in the ASA say? There is also some logging on the client, but I've found the logs in the ASA a little better.
auraza Tue, 09/22/2009 - 12:08
Please try to make sure you have started Firefox at least once under the user profile, as AnyConnect uses the mozilla cert store. Let me know if that allows it to work.
Also, which distro are you using?
