Call to a rerouted DN
Answered Question
Aug 21st, 2009
Hi There
We have a CUCM 6.1 and some Peoples want to reroute their calls to the Central, because they would be DND.
Now the Central should have the choice to reach the DND User and ask the Person if he want the call, because it's a important call. Additionally the central has to able to forward the call.
Give it any Feature to implement this scenario?
Correct Answer by Rob Huffman about 7 years 7 months ago
Hi Patrik,
There is a feature, which is called "CFA Destination Override" is available in CCM 5.x, CCM 6.x and CCM 7.x. Have a look;
Cisco Unified CallManager provides a service parameter (CFA Destination Override) that allows the administrator to override Call Forward All (CFA) when the target of the CFA calls the initiator of the CFA, so the CFA target can reach the initiator for important calls. In other words, when the user to whom calls are being forwarded (the target) calls the user whose calls are being forwarded (the initiator), the phone of the initiator rings instead of call forwarding back to the target. The override works whether the CFA target phone number is internal or external.
When the CFA Destination Override service parameter is set to False (the default value), no override occurs. Ensure the service parameter is set to True for CFA override to work. See Service Parameters Configuration in the Cisco Unified CallManager Administration Guide, Release 5.0(4), for information about configuring service parameters.
Note CFA override only takes place if the CFA destination matches the calling party and the CFA Destination Override service parameter is set to True. If the service parameter is set to True and the calling party does not match the CFA destination, CFA override does not take place, and the CFA remains in effect.
From this CCM 5.1.(1) doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080739bb8.html
This only works from the phone that the Call Forward All is directed to, in this case the Central DN. So using Call Forward All will perfectly simulate DND and allow the Central to still call the user involved :)
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Fri, 08/21/2009 - 05:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Patrik,
Hope this helps!
Rob
