Failed ICMP from remote connection
Aug 21st, 2009
Good morning,
I recall using syntax to enable ping on a source interface, syntax is below. Unfortunately I have something hosed. I see this form of syntax for sla configuration only. I recall using this syntax (or simular) to correct problem with ping from local and remote locations.
ip icmp source-interface fastethernet0/0
Syntax was not used in sla configuration.
Peter Paluch Fri, 08/21/2009 - 06:41
Hello Tim,
I am sorry but I haven't heard of a command that would allow you to set the source address for ICMP echo packets globally. The only way to set the source IP address in the pings I know of is in the ping command itself, i.e.:
ping source fa0/0
Is this what you are looking for?
Best regards,
johnspaulding Fri, 08/21/2009 - 06:45
Im with peter on this one. I am only aware of ip sla operation and what peter mentioned, sourcing with the ping command.
