AAA Authorization on PIX
Answered Question
Aug 21st, 2009
I have set up authentication and Authorization on the PIX. Authentication works but Authorization fails. I try to debug but nothing shows up (on PIX or ACS), but it does if I debug Authentication
Correct Answer by Jagdeep Gambhir about 7 years 12 months ago
Make sure you have enable authentication ,
aaa authentication ssh console TACACS LOCAL
aaa authentication telnet console TACACS LOCAL
aaa authentication enable console TACACS LOCAL
aaa authorization command TACACS LOCAL
Incase it does not work pls get aaa config
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Fri, 08/21/2009 - 05:52
  • Red, 2250 points or more
~JG
networker99 Fri, 08/21/2009 - 05:59
-aaa authentication ssh console TACACS LOCAL
-aaa authorization command TACACS LOCAL
-aaa-server TACACS (inside) host [ip_address] [key] timeout 10
Jatin Katyal Fri, 08/21/2009 - 07:40
  • Cisco Employee,
PIX\ASA command authorization does require enable authentication in the config.
You need to turn on enable authentication:
Here is the command
JK
Jagdeep Gambhir Fri, 08/21/2009 - 08:24
Hi Lewis,
Pls add enable authentication command to make it work.
~JG
