Conference calling to an external keeps dropping
Answered Question
Recently we have discovered that conferncing of an external number keeps dropping that particular call. Conferencing internally is fine however the external calls keeps getting disconnected.
It is an h323 gateway. If you want I can send the sh run configs.
Any ideas?
Correct Answer by Jaime Valencia about 7 years 9 months ago
add the voice class codec on the voip dial peers
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 08/21/2009 - 06:39
  • Cisco Employee,
  • Hall of Fame,
    2011
Probably codec issues, if you're using SW CFB it only handles G711.
H323 by default uses G729 unless configured to do otherwise.
java
Correct Answer
Jaime Valencia Fri, 08/21/2009 - 07:06
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Jaime Valencia Fri, 08/21/2009 - 09:41
  • Cisco Employee,
  • Hall of Fame,
    2011
I have no idea of your dial plan or call flow, so...
java
karthi.sd Wed, 09/09/2009 - 03:58
hi,
Did u find out what the problem is ?
Am facing the same problem...Can you pls explain me what you did to fix this pls.
shiv
a.gooding Thu, 09/10/2009 - 17:02
  • Bronze, 100 points or more
just an input fellow trini :). are the calls being disconnected immedaitely or are they proceeding and then dropping after a while...if its the latter then it may not be codec but as Jaime was indicating we will need a little more to go on to find the exact cause of the issue. Of course dont post anything ip addressing etc that you think would be a security issue
sivakumar.kvp Thu, 09/10/2009 - 21:55
Thanks for your reply..
Its a Codec problem and the issue has been resolved :)
many thanks
shiv
