Peter Paluch Fri, 08/21/2009 - 07:01
  • Cisco Employee,
I suppose you are asking about Cisco router models here.
I believe that any router whose IOS is capable of running BGP will do in your situation. Even the 800 series with a proper IOS can run BGP. And of course, all higher platforms do as well - the 1841, 2801, 2811 and so on. Running a BGP receiving only a couple of routes from a pair of neighbors is not any particular load for your router. I would instead try to select a router basing on the throughput it has to provide for your network.
So don't worry about a router that runs BGP in your scenario. Focus on the routing capacity. You will then be able to select an IOS for that platform that contains the support for BGP.
By the way, do you know the Cisco Feature Navigator? It allows you to see which IOS supports a particular feature. You can use it to find the proper IOS feature set for your selected router.
http://cisco.com/go/fn
Best regards,
Peter
