Upgrade CUCM steps from 6.1(2) to 6.1(3)
Aug 21st, 2009
Hi, this is my first post.
my question is, whish are the steps for a success CUCM upgrade.
the actual version is 6.1.2.1000-13, and i want to upgrade to the 6.1.3.1000-16 version.
i have a Cluster, Publisher and Subscriber
i downloaded the version and burn into a DVD.
what's next?
thanks for your help
Overall Rating: 5 (1 ratings)
agustin.varela@... Fri, 08/21/2009 - 10:19
Great, thank's a lot.
now, i do that in lab. but an error appears.
attach the picture.
in that case i tried to upgrade from 6.1(2) to 6.1(4).
but this error, i don know what happend.
i download the image 3 times, and copy 3 times in difference DVD burners
thank's
agustin.varela@... Wed, 08/26/2009 - 06:03
hi, plz. i dont understand the error:
"Error encountered: An Unknown error occurred while accessing the upgrade File"
thx
Jaime Valencia Wed, 08/26/2009 - 06:13
make sure MD5 is correct, otherwise you might need to look at logs
java
if this helps, please rate
guilhem.perez Thu, 11/05/2009 - 01:49
my customer encounter the same issue:
6.1(2) to 6.1(3)and
6.1(2) to 6.1(4)too.
Did you solved your issue?
Thank you
Best regards
leightonfehr Thu, 11/26/2009 - 08:41
I have having the same error on an upgrade from 7.0.2.20000-5 to 7.1.3.20000-2
I am upgrading immediately after a fresh installation.  I have not started any services yet, could that be my problem?
I idd not choose to upgrade as part of the installation, instead I am using the Cisco Unified Operating System Administration to do the upgrade.
I am using OpenSSH as an SFTP server on a Windows machine.  The file downloads fine, and produces this error after about 30 minutes into the upgrade process "Error encountered: An unknown error occurred while accessing the upgrade file."
The MD5 check on the combined ISO file is good.
Any suggestions?
ogmez Tue, 09/10/2013 - 07:37
hi:
I have the same problem in my CUCM 6.1.2 ....(source version is 6.1.2.1000-13 ..),
and i need to upgrade to 6.1.4 but, i get the same error:
.....Error encountered: An unknown error occurred while accesing the upgrade file.
who solve it yet ????
any suggestion please y reale want to upgrade to this version
ill be trying :
     UCSInstall_UCOS_6.1.4.1000-10.sgn
     UCSInstall_UCOS_6.1.4.2190-3.sgn
but nothing , i get the same error
i hope any one can answer me.
....Cisco:::
