cor 101
Aug 21st, 2009
I am trying to get my head around class of restriction. Found a good link below:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
But I still do not understand this definition.
dial-peer cor custom
name local_call
Where do the "local_call" defined?
How the system know what are the local_call numbers?
Overall Rating: 4 (2 ratings)
Jaime Valencia Fri, 08/21/2009 - 10:22
Think of this as something similar to CSS and partitions
Dial-peer cor custom
name local_call
Above is partition
Dial-peer cor list calllocal
Member local_call
Above is CSS
Dial-peer voice 1 voip
Destination-pattern 408….
Session target ipv4:1.1.1.1
Corlist outgoing calllocal
It's all really nicely explained in the link, take some more time to review and understand it.
java
if this helps, please rate
smallrain_2 Fri, 08/21/2009 - 11:14
I think I understood the logic.
But still unable to figure out what is in "local_call".
For example, partition has dn, rp, tp, and etc. What is in "local_call"?
Jaime Valencia Fri, 08/21/2009 - 11:33
All this is from the same link:
Member local_call
Ephone-dn 1
Number 1001
Cor incoming Engineering
Dial-peer cor list Engineering
Member 911
Member local_call
Ephone-dn 1 (1001) can call 408…., 911, and 316….numbers.
A better description of how this works is to think of it as locks and keys.
The phone COR needs to be a sublist of the DP COR to make the call. If you don't have the necessary keys, you can't call. All is in the link.
java
smallrain_2 Fri, 08/21/2009 - 12:35
Java,
Please forgive me for keep asking same question. May be I am so dumb. ;)
I knew I was missing very fundamental.
I still don't understand how CME match local_call with 408.... and 316.... pattern. Or even 911 pattern.
911, local_call were defined under dial-peer cor custom with "name" keyword. To me, all those 911 and local_call are ascii (not digit).
How CME match/translate to numbers?
For example, local_call to 408.... and 316.... pattern.
I understand all partition/css analogy and lock/key mechanism. I am started feeling ashame about asking more questions. ;)
Adrian Saavedra Fri, 08/21/2009 - 14:37
Hi friend,
First, imagine we have to create a label (local_call):
name local_call
Second, imagine we have to create a box (calllocal) and we have to assign it a label (local_call):
member local_call
Then, in this box "calllocal" we will put inside our dial peer (destination pattern or route pattern). This will be done with the command corlist outgoing.
Destination-pattern 408....
Next, we have to create the permissions (or CSS):
Member 911
Member local_call
If you see, the CSS is composed by a list of labeled boxes. In this case, CSS Engineering will search for boxes labeled "911" or "local_call", so a phone can reach the destination pattern that is inside and then the call be routed properly.
You assign CSS to a phone with the command corlist incoming:
Ephone-dn 1
Number 1001
I hope it helps you understanding COR, if it does please rate.
Best regards,
- Adrián.
smallrain_2 Fri, 08/21/2009 - 19:47
Thanks Adrian and Java.
Ok. I was confused with lables and digit.
While I was started reading I thought 911, local_call digit or digit alias.
Adrian, your box and label analogy help.
Soon after I saw them as lables, everything click!!!
Thanks again,
