Pix515 E and VPN Client
JORGE RODRIGUEZ Fri, 08/21/2009 - 14:10
  • Green, 3000 points or more
If you are running code version 7.x in your PIX you need this link configuration .
Local-LAN access while internet is still encrypted through asa.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702992.shtml
If your PIX is still under 6.x above link is not feasable , therefore you need split tunneling configuration - no internet will be encrypted through the tunnel but through your regular internet, and access to your local lan resources.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702999.shtml
JORGE RODRIGUEZ Sun, 08/23/2009 - 14:59
Kendall, are you still having issues? if so pls post your config to assist.
